Zabbix Discovery not working as intended
  • FH26
    • Feb 2022
    • 15
    Hey,
    I have a discovery for the IP Range 10.12.200.0/22, so theoretically 10.12.200.1 - 10.12.203.254,
    but the discovery only discoverys hosts from 10.12.200.1-10.12.200.254. nothing after that.
    When I set it discovery 201, 202 and 203 individually it works.
    Why doesn't the discovery work with the /22 behind it?
  • Hamardaban
    • May 2019
    • 2714
    I use the rules with the mask /23 - everything works.
    You can try to specify a range in the form 10.12.200-203.1-255 .
    Note that it is recommended to make the range not too large because detection can take a long time with timeouts.
    It is better to make several discovery with smaller ranges and increase the number of discovery processes.
    • FH26
      • Feb 2022
      • 15
      I've found the problem. I was chetting snmp oids and this caused it to stop weirdly.
      Maybe the timeout isnt configured correctly
