Multilink interfaces and LLD
  • StarDestroyer
    • Jun 2014
    • 20
    I have an office out in an area where T1 lines still rule the land. In order to get decent speeds, I have multiple T1's bonded together into a single Multilink interface.
    Zabbix has discovered the individual T1 interfaces as well as the Multilink interface on my Cisco router.
    I also have Zabbix configured to send me text messages on High and Disaster level events on certain critical pieces of infrastructure (such as our routers).
    The problem I have is that I want a text message on the multilink interface going down, but am not as concerned with a single T1 line going down (I'd still like to know, but I don't need to know instantly at 2am). While I can disable the notifications altogether for the individual T1 lines, what I'd much rather do is able able to set those to "Average" severity while leaving the Multilinks as "High" ... trouble is, I can't seem to find a way to change the severity of a single discovered interfaces... I could change it in the template, but then it changes it for all the discovered interfaces.
  • LenR
    • Sep 2009
    • 1011
    Can you create a filtering rule for T1's vs. multilink? If so, you would have to clone the discovery for one, then change the triggers, then use both to get complete coverage.
    I did something similar for selected file systems, one discovers only those, the other discovers NOT those.
