Issue with Macros
  • guest6936
    • Mar 2022
    • 25
    Issue with Macros
    Running Zabbix 6.0.1
    I am trying to translate a macro to a variable as the image below shows. However, when I test my Item I receive the following error
    Invalid parameters: parse "https://{HOST.NAME}": invalid character "{" in host name.
    We're trying to monitor SSL certificates using a template, and without having to specify the CERT.WEBSITE.HOSTNAME for every site. Conveniently our HOST.NAME are named foobar-XXX.domain.com
    I would wish that {$CERT.WEBSITE.HOSTNAME} should resolve itself to {HOST.NAME}, but no.
    HTML Code:
    web.certificate.get[{$CERT.WEBSITE.HOSTNAME},{$CERT.WEBSITE.PORT},{$CERT.WEBSITE.IP}]
Name:	Screenshot 2022-03-18 at 12.26.42.png
  • cyberphantom
    • Dec 2021
    • 67
    I think you can't do this... according to the manual, there's nothing about put a macro inside another macro value
    But why you don't modify the template from this "{$CERT.WEBSITE.HOSTNAME}" to just this "{HOST.NAME}"?...
    • guest6936
      • Mar 2022
      • 25
      Yeah, that makes perfect sense. Thanks.
