I'm confused about which syntax to use for aggregated calculated items.
I have a working calculated item that uses the syntax:
Key: junos.rpm.probe.NETARCH.loss.[{#SNMPINDEX}]
Formula: (1 - last("junos.rpm.probe.NETARCH.ProbeResponses.[{#SNMPINDEX}]") / last("junos.rpm.probe.NETARCH.ProbesSent.[{#SNMPINDEX}]")) * 100
And this works.
I'm trying to create another item which would add up all junos.rpm.probe.NETARCH.loss.[*] in a single item.
This seems to describe a different syntax than the one I used above:
So when I use this:
Formula: sum("junos.rpm.probe.NETARCH.loss.[*]")
I get the error:
Cannot evaluate function "sum()": item "cr01-cnco01.tingfiber.net:junos.rpm.probe.NETARCH.loss.[*]" does not exist.
While I do have items like these on the host:
And this works.
So when I use this:
I get the error:
- junos.rpm.probe.NETARCH.loss.[""XXXX""]
- junos.rpm.probe.NETARCH.loss.[""YYYY""]
