Log Monitoring with Zabbix
  • fabiopig
    • Mar 2022
    Good morning everyone,
    first of all a greeting to all, I am a new user of the forum.
    I am writing to ask you for a help in configuring Zabbix for monitoring Log files.
    The version of Zabbix in use is: Zabbix 5.0.12 on Docker desktop.
    I configured Zabbix to read the contents of a log file of a CentOS 7 server, creating a Log_Monitoring template and inside it, I created a Log item configured as follows:
    Type: Zabbix Agent (Active)
    Key: log[/var/log/applicazione.log,,,,skip,,,] ho provato anche log[/var/log/applicazione.log,,,,skip,,]
    Type Information: Log
    Update interval: 1s
    History storage period: Storage period 90d
    I followed the official guide for configuring the Template and it seems to me that I have done everything correctly, but the log is not received by zabbix. On this server I have also enabled other templates such as Template Module Linux filesystems by Zabbix agent, which work regularly.
    On the client in /var/log/zabbiz/zabbix_agentd.log I have no particular errors and the last line says:
    31680: 20220318: 102811.088 active check configuration update from [xxx.xxx.xxx.xxx:10051] is working again
    hich makes me understand that the active mode agent works regularly. On the other hand, I cannot view the server log files, as I cannot find them in the Docker container.
    I hope someone can help me solve this problem that has been gripping me for some time.
    Thank you
  • Rak
    • Mar 2022
    Please try with this..
    Key: log[/var/log/applicazione.log, "ho provato anche ",,,skip,,]
    • Rak
      • Mar 2022
      Key: log[/var/log/applicazione.log, "ho provato anche",,,skip,,]
      • vitS
        • Apr 2021
        • 43
        You can find logs by typing: docker logs <container name of zabbix server> ( In Powershell or Command Prompt )
        or
        Find where containers placed ( In *NIX /var/lib/docker/container/.. ) and there will be json-log
        or
        Map new volume to zabbix server container: - <local path>:<path to zabbix logs in container>
        • fabiopig
          • Mar 2022
          Thanks for response,
          i think i made a mistake in the first post, i tried both:
          Key: log[/var/log/applicazione.log,,,,skip,,]
          I also tried what you suggested
          but nothing has change, the logs don't came to zabbix server
          • jramirez
            • Apr 2022
            Hi every One. Hope you are well.
            Some one who be so kind to tell me where to find and download a valid/trusted Zabbix Module for PS.
            Many thanks and regards.
            • Rak
              • Mar 2022
              Can somebody help me on how can I capture previous and next two lines of a matched keyword in a log file. I am still a beginner so it would be nice if you can share detailed steps.
              [TIME]=2022/03/29 08:01:47
              [TYPE]=E
              [MSG]
              Machine : WS-A01, Module: CTS RequestProcessing, generation Time :Tue Mar 29 08:57:47 XYZ 2022, Message :Long Processing Time: 2036 ms-MessageType: ABC EFG LOOKS LIKE A SYSTEM ERROR-GId: 2341-RequestId: WS-A01~REPORT~1234b14d72e912:2437ce83
              [ACTION]
              My keyword will be [TYPE]=E so where ever [TYPE]=E will be found it should capture the line above this and 2 lines just below this keyword line.
              Thanks in advance.
              Rak
                Explore and test this PCRE2 (PHP) regular expression online. Understand the pattern with regex explanations, generate code, and export matches to CSV or JSON.
                At least it works in regex101...
                • ap2022
                  • Nov 2022
                  Unfortunately it works only in regex101, but it doesn't seem to work in zabbix.
                  I've tried a lots of ways to capture line by regex and several lines after it (using and not using s,m and x modificators, [[:space:]],^,\n,$ symbols in lots of variations) and haven't succeeded :-(
                  My conclusion​: Zabbix preprocessing perfectly works with multiline text data by regex, but zabbix agent is not able to capture multiple lines from log files by regex.
                  • Hamardaban
                    • May 2019
                    • 2714
                    The agent handles the log lines as they are “created”. Line by line.
                    There's no idea "many lines" for the agent.
