Zabbix 6.0 with PfSense (SNMP or Agent plugin)?
  • Adrianoebm
    • Mar 2022
    Hello everyone, my first post.
    What is the best way to monitor a PfSense (SNMP or Agent Zabbix) to monitor the status of IPSec tunnels and how should I set correctly the value if there is no value field in version 6?Click image for larger version
  • Adrianoebm
    • Mar 2022
    I did it, i figure out what values to input.Click image for larger version
    • Adrianoebm
      • Mar 2022
      Now i must figure out how to monitor IPSEC and OpenVPN Tunnels.
      • Adrianoebm
        • Mar 2022
        Someone, please help!
        • Adrianoebm
          • Mar 2022
          Ok, after some coffees and a lot of search i import an old template i found in GitHub.
          Zabbix Template for pfSense. Contribute to rbicelli/pfsense-zabbix-template development by creating an account on GitHub.
          Im not sure if it is the best way to collect this kind of data, i just want a status of my ipsec. (10 Total)
          Here is an example.
          • Adrianoebm
            • Mar 2022
            If zabbix and pfsense are so popular why did this kind of update take so long? I just wanted a status of my ipsec
              Zabbix does not create templates for every possible device there is. It would require having all those devices at hand, having all the knowledge about them etc. They do provide templates for widepsread things, OS-es etc. they probably have those things in use in their office, easy to test them etc. That's why they have community, who can spend their own time, if they wish to contribute (just like the template you imported). And then people like You, can use the results of that contribution. Time spent by someone and given out free of charge.. You really should not expect that everything is ready for every time You need it...
              There is a choice... if you do not contribute time by yourself, I am pretty sure they will accept monetary compensation together with your request for specific template..
