Template for Lenovo Servers
  • suatugurlu
    • Mar 2022
    Hello all,
    is there any template for Lenovo ThinkServer series servers?
    I can see there was a template named "template-server-lenovo-xcc-snmpv3" which is not shared anymore.
    If there is someone having this template or equal one, can you please share?
    regards,
  • bkmz123321
    • Apr 2022
    Hi I need this template too. I managed to contact the author and he gave it to me, how can I send you a template?
    • RobertoX
      • Jul 2020
      Can you share this template here in forum???
      • bkmz123321
        • Apr 2022
        Template in the attachment
        • jtnfoley
          • Mar 2022
          • 82
          Linked template failure?
          • Cannot import template "Template Server Lenovo XCC SNMPv3", linked template "Template Module Generic SNMPv3" does not exist. [zabbix.php:22 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerPopupImport->doAction() → CApiWrapper->__call() → CFrontendApiWrapper->callMethod() → CApiWrapper->callMethod() → CFrontendApiWrapper->callClientMethod() → CLocalApiClient->callMethod() → CConfiguration->import() → CConfigurationImport->import() → CConfigurationImport->processTemplates() → CTemplateImporter->import() in include/classes/import/CConfigurationImport.php:654]
          • jtnfoley
            • Mar 2022
            • 82
            I walked the dependencies in the xml file and found that I could change the "Template Module Generic SNMPv3" to get a successful import into v6.0.2:
            <templates>
                   <template>
                   <name>Template Module Generic SNMPv3</name>
                   </template>
            </templates>
            now:
            <templates>
                  <template>
                  <name>Generic SNMP</name>
                  </template>
            </templates>
            I'll test on my IMM2 servers and check back in.
            • jtnfoley
              • Mar 2022
              • 82
              I had to make a number of adjustments for IMM2 on an x3550 M5, IMM2 FW 5.3.
              I pulled the MIBs from a more recent firmware update and used them for reference and changed from XMM to IMM, successfully. If anyone wants a copy HMU.
              Edit: I was mostly successful porting this template to my M5 servers. LLD Item discovery is not working completely yet. I'll try to make time in the near future.
              • joeclubberlang
                joeclubberlang commented
                could you please share your template
            • jtnfoley
              • Mar 2022
              • 82
              Still incomplete, observed LLD issue not addressed at all. Still, have at it:
              • stsnurr
                • Nov 2022
                Hi
                Been a HPE shop until now, and just put a SR645 in production. Template for HPE ILO interface has(beside some timeout issues on ILO firmware 2.72) flawless. Wondering if anyone has had any sucess with the Lenovo XCC template discussed here, or have any good alternatives?
                • zumi.fi
                  • Jan 2023
                  Hello! Looking also for complete XCC template. Seems like the support for XCC is terrible in all ways.
                  I might need also to make my own template. Where did you find the MIBs?
                  • rabin
                    • Nov 2020
                    • 10
ID:	467839 Under the LXCC download, see details here: https://datacentersupport.lenovo.com...ITY-CONTROLLER
                    • ramyaranjan
                      • Sep 2023
                      Hi All, Can I get SNMP templet to monitor for ThinkSystem SR650​ .
                      • vijayk
                        • May 2023
                        • 305
                        See the attached file.
                        • ramyaranjan
                          ramyaranjan commented
                          I am getting error while importing, Kindly help me on this .
                          Cannot import template "Template Server Lenovo XCC SNMPv3", linked template "Linux by SNMP" does not exist.
                        • vijayk
                          vijayk commented
                          Template Linux by SNMP is required. Please import 1st this template and then try.
                        • ramyaranjan
                          Vijayk thank you for your prompt response ,I am not understanding which templet I should import 1st .
                      • lowsval
                        • Oct 2023
                        the version in 6.0 is not avalaible for this template
                        • vijayk
                          • May 2023
                          • 305
                          #15
                          Try with this template. Template SNMPv3 Lenovo XCC.zip
