Font Size on 40" TV (Screens)
  • dordetto
    • Dec 2015
    I'm showing Zabbix monitoring on an LCD TV (FullHD) but the font size is too small, making it difficult to see from afar.
    I'm using "SCREENS" module "HOST ISSUES"
    I need to increase the size of that source, is it possible?
  • michael.weber
    • Nov 2015
    • 121
    Idea: Change browsers "zoom".
    Internet Explorer: CTRL + Mouse Wheel
    • dordetto
      • Dec 2015
      The problem is that I use a Raspberry plugged into the TV, without mouse or keyboard. I'll check if the Browser is to put the zoom by default.
      • ingus.vilnis
        • Mar 2014
        • 908
        As an option you can use any web developer tools like Google's Inspect element to see from which file you get which sizes and then adjust them in Zabbix CSS files accordingly.
        Directory /styles/ is used to store all those CSS files.
        Hope this helps!
        Best Regards,
        Ingus
