TimescaleDB DB size increasing
  • Valinor
    • Sep 2020
    • 20
    I've migrated to TimescaleDB a few months ago, it works well since, but db size has been increasing constantly and significantly(from 500GB to 2TB).
    The number of host increased during that time, but not so much.
    I've checked tables size and it seems that most of it are history:
    hypertable_name | hypertable_size
    history | 536148967424
    history_uint | 916502667264I;
    history_str | 246494855168
    history_text | 206778114048
    history_log | 29433192448
    trends | 13386760192
    trends_uint | 20786864128
    I've tried to change the housekeeping setting(compression is enabled from start for minimum 7 days), but it didn't affect db size mostly.
    Any advise what to check?
