Basic CPU alert
  • yatta
    • Feb 2022
    • 82
    Basic CPU alert
    I just want to create a basic high CPU alert and send to Teams. But Zabbix GUI and logic is so complex in my opinion. Items, triggers, events and actions.. Just couldn't understand how to do that.
    Can you please help how to send a basic CPU alert for all hosts to Teams?
    (I set Teams configuration already and it works fine.)
    Regards.
  • yatta
    • Feb 2022
    • 82
    I'm trying to create a trigger, so I clicked "Confuguration-->Hosts" and clicked any Trigger link from a host's row.
    But it seems this trigger has been creating specifically for that host? I want to create a generic alert/trigger for all hosts, how can I do that?
    Secondly, as you can see on the SS, what can be put the textbox at "Last of T"? Is this second, minute or what? (Why there is no a basic explanation in that box?)
    Regards&thanks!
    • incama
      • Jan 2015
      • 66
      Maybe then Zabbix isn't for you.
      • lasseoe
        • Aug 2008
        • 15
        Regards.
        It's really not that complicated compared to most other monitoring tools.
        Perhaps you need to take a course and learn the basics, https://www.zabbix.com/training_cour...rtified%20user
        • yatta
          • Feb 2022
          • 82
          Zabbix is really complicated, I wouldn't use if business unit didn't decide to use Zabbix. Forcing them to use another solution but no decide yet. Creating a basic alert is also needs pretty much effort.
          Unfortunately that courses are paid but thanks, I'll try some other Youtube courses.
