Hi I am trying to create two different templates and want to link it to same item with key snmptrap.fallback. can i edit the xml directly so as to it assign it to same hosts without any errors. if so how can i do it?
I can have this item in anyone of template.
<item>
<name>V Traps</name>
<type>SNMP_TRAP</type>
<key>snmptrap.fallback</key>
<delay>0</delay>
<trends>0</trends>
<value_type>TEXT</value_type>
<triggers>
</item>
any pointers will be helpful thanks
Thanks in advance
<item>
<delay>0</delay>
<trends>0</trends>
<triggers>
</item>
Thanks in advance
