LLD with {$HOST.IP} as parameter
  • HLS88
    • May 2021
    is there a way to set the IP of the Host interface of a LLD Rule as an parameter of the LLD Key?
    If I run this on a host I got this error:
    "Invalid discovery rule value: cannot parse as a valid JSON object: invalid object format, expected opening character '{' or '[' at: 'snmpwalk: Unknown host ({$HOST.IP}) (Invalid argument)[ ]'"
    So the Macro {$HOST.IP} is not solvable.
    Have you defined that user macro anywhere?
    If you want to use that particular hosts IP, then you should use {HOST.IP} (without $)
