Zabbix 6, agent2, TLS certificate monitoring
  • rsokoll
    • Jun 2018
    • 11
    I'm pulling my hair out - I do not get it. I've read https://www.zabbix.com/documentation...eb-certificate
    I can do
    zabbix_get -s 127.0.0.1 -k web.certificate.get[google.com,,]
    and parse the result with jq - so basically, it works.
    But how in the world I get certificate monitoring, say, for google.com, into zabbix itself?
    Somehow, I'm blind :-(
  • Atsushi
    • Aug 2013
    • 2028
    If you have newly installed Zabbix 6.0, please refer to the template "Website certificate by Zabbix agent 2".
    https://git.zabbix.com/projects/ZBX/...Frelease%2F6.0
    • rsokoll
      • Jun 2018
      • 11
      OK, got it, thank you. Now I have another problem. Let's assume I want to monitor a Service that is run by another organization. Maybe a mailserver with webmail, submission and IMAPS. For service monitoring, I would use the address (or DNS name) of this server for the agent interface. But when I want to use the certificate template, it will not work, because the template needs an agent2 which actually performs the checks, correct? So either I can do service monitoring OR certificate monitoring, but not at he same host. Or am I wrong?
