UserParameter Permission denied
  • miramira007
    • Sep 2015
    • 89
    Hey all,
    sorry for asking such a dummy question. But yet i haven't got anyone to ask. Maybe someone here can help me.
    I want to monitor a deamon in centos via UserParameter.
    To testing i created in server x zabbix agent a UserParameter, which looks like this here:
    UserParameter=services.check.name, sudo systemctl status name | grep -c running
    Gave zabbix all privilegies via visudo. the copy is here:
    zabbix ALL=(ALL) ALL
    I know it isn't the best way (maybe the dirtiest one, but this all is just a testing now)
    After creating an item, i have got an error. This one:
    sh: /usr/bin/sudo: Permission denied
    0
    What should i do? I haven't got an idea, where the problem can be.
    I think i made a mistake in the sudoers file? First i edited it with nano! Maybe this can be the reason?
    Thanks a lot,
    mira
  • ingus.vilnis
    • Mar 2014
    • 908
    Few suggestions:
    1. Try editing the file with command "visudo"
    2. Instead of zabbix ALL=(ALL) ALL add the following line:
    zabbix ALL = NOPASSWD: /sbin/systemctl
    Otherwise it will still ask for password when executing this command.
    Hope this helps!
    Best Regards,
    Ingus
    • miramira007
      • Sep 2015
      • 89
      Thank you for your answer,
      i edited the sudoers file with visudo like your suggestion, but it hasn't changed anything
      Maybe an other idea? My Zabbix Server and Agent are running on a CentOS 7. Both are in version 2.4.7.
      • ingus.vilnis
        • Mar 2014
        • 908
        If possible, temporary disable SELinux and try again if that helps.
        setenforce 0
        Then check /var/log/audit for zabbix agentd related errors. Create policies if needed.
        Best Regards,
        Ingus
        • miramira007
          • Sep 2015
          • 89
          For testing i disabled SElinux,
          added this in /etc/sudoers
          Defaults: user !requiretty
          And now it works.
          Im such a dummy! I know i havent got to say it, because you can notice that from my question!
          Thanks a lot.
          mira
