Zabbix agent 3.2.1 on Ubuntu 20.04
  • aitormg
    • Apr 2022
    Hello
    I'm trying to install the zabbix-agent 3.2.1 in a new ubuntu server 20.04 but i have some problems with dependencies
    Why i'm doing this?
    I installed zabbix-agent 3.4 and it worked fine but it always fails next day at 6:00 AM
    From this moment it doesn't work and i need to reinstall the agent.
    The error that i have in my lzabbix server is "received empty response from zabbix agent at [XXX.XXX.XXX.XXX] assuming that agent dropped connection.
    The configuration we thing is ok because it works for some hours but then doesn`t
    regards
  • aitormg
    • Apr 2022
    I'm trying to install zabbix-agent 3.2.1 because our zabbix server is 3.2 and the agent we deploy in the windows servers is that version.
    • Atsushi
      • Aug 2013
      • 2028
      There is no official package, so compile and install from source. If installation from source is difficult, please consider upgrading Zabbix server.
      • aitormg
        • Apr 2022
        Thank you, we'd like to upgrade Zabbix server but is not our call
        And yes, installation from source is difficult. We only work with Windows and the most basic tasks are like other languaje for us.
        Could you show me a link for the software/files that we need and we'll search a procedure to do it
        Thanx
        • incama
          • Jan 2015
          • 66
