Help with trigger expression
  • svsjmallory
    • Apr 2022
    I'm on zabbix 5.4. I have an issue with a custom trigger I've configured. The item being checked returns nothing if everything is ok. If there is a problem, then it returns data. I'd like the trigger to go off only if there's been a problem for more than five minutes. I've the expression below, but it's still going off on a single check of the service.
    min(bitlength(last(/Docker Swarm/docker.services-crit)),5m)>1
    Obviously, I'm not doing something right. What should I change?
    Currently your expression is based on just last value, it really does not consider age, as that 5m, what you define there (min(.., 5m)), means "within last 5 minutes". So, of course it will fire right away, when data comes in.
    you could try with
    count (/host/key,(sec|#num)<:time shift>,<operator>,<pattern>)
    count(/Docker Swarm/docker.services-crit),5m)>=5
    If you do not have 5 values during last 5 minutes, then it should not fire...
    • svsjmallory
      • Apr 2022
      Thanks. I tried the syntax you provided above, and it throws an alert immediately. I think maybe because the item itself returns a string, and count doesn't handle that. That's why I've been using the bitlength function.
        Count can handle all kind of data. It really does not count, what are you counting..
        Supported value types: float, integer, string, text, log
        But thinking of this.. recalculation takes place, when new values arrive, so if nothing will come in it will not be recalculated and trigger stays active ...
        I think your best option would still be to return something every time check runs.
