SSH Connection Permission Error
  • Zetter
    • Jan 2016
    I'm trying to get value like "service --status-all" with SSH connection but I couldn't connect to device with SSH.
    I created Item;
    Type : SSH agent
    Key : ssh.run[test,x.x.x.x,22,utf-8]
    Host interface : My Zabbix Real IP address (I didn't use 127.0.0.1)
    Authentication method : Password
    Username : myServerUsername (which is I try to connect)
    Password : myServerPassword
    Executed script : service --status-all
    Type of information : Text
    Update interval (in sec) : 30
    Then when I check my item in Items menu, I get an error
    Status : Not Supported
    Info : Cannot connect to SSH server: cannot connect to [[x.x.x.x]:22]: [13] Permission denied.
    How could I solve this problem? Basically I want to connect my servers with SSH and I want to get service status list from my servers. Can I do that with Zabbix Server?
    Thanks for all your help!
    Regards
  • Atsushi
    • Aug 2013
    • 2028
    Can you log in using the ssh command from prompt to that host?
    • Zetter
      • Jan 2016
      Absolutely, I can login to that server both my computer and zabbix server via SSH.
      • Zetter
        • Jan 2016
        Also this is my log file,
        #tail -f /var/log/zabbix/zabbix_server.log | grep ssh
        5958:20160108:132930.689 In substitute_key_macros() data:'ssh.run[ssh2,x.x.x.x,22,utf-8]'
        5958:20160108:132930.689 End of substitute_key_macros():SUCCEED data:'ssh.run[ssh2,x.x.x.x,22,utf-8]'
        5958:20160108:132930.689 In get_value() key:'ssh.run[ssh2,x.x.x.x,22,utf-8]'
        5958:20160108:132930.689 In ssh_run()
        5958:20160108:132930.690 End of ssh_run():NOTSUPPORTED
        5958:20160108:132930.690 Item [Streaming:ssh.run[ssh2,x.x.x.x,22,utf-8]] error: Cannot connect to SSH server: cannot connect to [[x.x.x.x]:22]: [13] Permission denied
        5981:20160108:132932.401 item "Streaming:ssh.run[ssh2,x.x.x.x,22,utf-8]" became not supported: Cannot connect to SSH server: cannot connect to [[x.x.x.x]:22]: [13] Permission denied
        • Zetter
          • Jan 2016
          Still I've same problem :/
          Any suggestion about this?
          • Atsushi
            • Aug 2013
            • 2028
            Can you login with user and password that you set the item?
            Can you execute that command by that user?
            • Zetter
              • Jan 2016
              Yes I can login to server with user and password which is used in the item. Also I can execute command with that user.
              Actually, I'm pretty sure Zabbix couldn't connect to my server because when I created account, I'm getting error like "Cannot connect to SSH server: cannot connect to [[x.x.x.x]:22]: [13] Permission denied".
              Thank you,
              • Atsushi
                • Aug 2013
                • 2028
                Do you use SELinux?
                If you use SELinux, please check audit log.
                ex. RHEL or CentOS
                /var/log/audit/audit.log
                • Zetter
                  • Jan 2016
                  Do you use SELinux?
                  ex. RHEL or CentOS
                  Hi Atsushi,
                  I use RHEL and checked my audit.log but I'm not sure this is normal or not. Does it tell anything to you?
                  Thank you so much for your helps!
                  type=AVC msg=audit(1452576139.223:97083): avc: denied { name_connect } for pid=5975 comm="zabbix_server" dest=22 scontext=unconfined_u:system_r:zabbix_t:s0 tcontext
                  =system_ubject_r:ssh_port_t:s0 tclass=tcp_socket
                  type=SYSCALL msg=audit(1452576139.223:97083): arch=c000003e syscall=42 success=no exit=-13 a0=7 a1=d040c0 a2=10 a3=40 items=0 ppid=5947 pid=5975 auid=0 uid=496 gid=491
                  euid=496 suid=496 fsuid=496 egid=491 sgid=491 fsgid=491 tty=(none) ses=13 comm="zabbix_server" exe="/usr/sbin/zabbix_server_mysql" subj=unconfined_u:system_r:zabbix_t
                  :s0 key=(null)
                  type=AVC msg=audit(1452576139.226:97084): avc: denied { name_connect } for pid=5975 comm="zabbix_server" dest=23 scontext=unconfined_u:system_r:zabbix_t:s0 tcontext
                  =system_ubject_r:telnetd_port_t:s0 tclass=tcp_socket
                  type=SYSCALL msg=audit(1452576139.226:97084): arch=c000003e syscall=42 success=no exit=-13 a0=7 a1=d040c0 a2=10 a3=40 items=0 ppid=5947 pid=5975 auid=0 uid=496 gid=491
                  :s0 key=(null)
                  • Atsushi
                    • Aug 2013
                    • 2028
                    There are log message that the connection was denied by SELinux.
                    type=AVC msg=audit(1452576139.223:97083): avc: denied { name_connect } for pid=5975 comm="zabbix_server" dest=22 scontext=unconfined_u:system_r:zabbix_t:s0 tcontext=system_u:object_r:ssh_port_t:s0 tclass=tcp_socket
                    It has refused that zabbix_server tries to connect with SSH port number(22) of TCP socket.
                    Please change the settings of SELinux policy.
                    ex. CentOS 7.2 + MariaDB 5.5.44 + Zabbix 2.4.7
                    # getsebool -a|grep zabbix
                    httpd_can_connect_zabbix --> off
                    zabbix_can_network --> off
                    # setsebool -P httpd_can_connect_zabbix on
                    # setsebool -P zabbix_can_network on
                    • Zetter
                      • Jan 2016
                      Solved!
                      Yesss, it works! I don't know how to thanks to you! Thank you so so much..
