Zabbix : Item already exists, inherited from another template
  • abiswas
    • Apr 2015
    We apply zabbix template to the server using the "import" option available in UI. Say, template A is linked with another template B and the templates are applied to the zabbix server.
    In the next version/release :
    1. Template A is no longer associated with B
    2. Template A is linked with a new template C
    3. Items from B has been moved to C (C is a superset of B).
    Now if I try to import the latest version of the template (A -> C) on top of older version (A -> B) from the "import" option in UI, I get the following error :
    Item "<Item_Key>" already exists on "<Template_Name>", inherited from another template.
    But, as you can understand, in the latest version of the template (A -> C), template B is no longer there and hence there is no question of conflict between items in B and C.
    Zabbix Version : 2.4.7
  • abiswas
    • Apr 2015
    Steps to reproduce
    Steps to reproduce :
    1. Import attached zbx_export_templates-A.xml first. It has "Template A" linked to "Template OS Linux" (which comes out of the box with zabbix).
    2. Import attached zbx_export_templates-Another.xml on top of #1. zbx_export_templates-Another.xml has "Template A" linked to another template "Another OS Linux" (which is a deep clone "Template OS Linux". This is to make sure that "Template OS Linux" and "Another OS Linux" have common elements).
    #2 returns :
    Template "Template OS Linux" with item key "agent.hostname" already linked to host.
    The templates are provided as attachment.
    Archive.zip
    • asaveljevs
      Zabbix developer
      • Feb 2010
      • 36
      Looks like a bug indeed. Please report it on our tracker at https://support.zabbix.com/browse/ZBX/ .
      • abiswas
        • Apr 2015
        Thanks for confirming. I have raised the following bug :
