Geomap Disable Pin Grouping
  • hg2552
    • Apr 2022
    I do not see in the documentation where you can disable grouping by proximity in the geomap. For instance, instead of displaying 3 hosts under a pin with the number 3 on it, just display those 3 pins regardless of zoom level.
    Is this possible in the configs or code somewhere?
    Thank you
