HOST.IPx not working as expected
  • LenR
    • Sep 2009
    • 1011
    We were working on some net.tcp.service items (Zabbix 5.0) where the host had services on IP's other than the primary ip. We already had the host dns and ip as the default agent interface. We added 2 more agent interfaces which I thought would be {HOST.IP2} and {HOST.IP3}. Basically, results were unpredictable, watching the traffic with tcpdump at the proxy, both of these macros were using IP3. Using the interface on the item worked, but we eventually want to move this to a template and that's not available.
    To circumvent, I just made user macros for each and that works. On one hand, that is a better idea, because I'd bet someone would put these interfaces in the wrong order.
    Has anyone else seen anything like this?
  • Semiadmin
    • Oct 2014
    • 1626
    It's normal because {HOST.IP<N>} means ip of the N-th host in trigger expression, not ip of the N-th host interface.
    In template you may use an internal LLD rule zabbix[host,discovery,interfaces] and net.tcp.service as item prototype.
    • LenR
      • Sep 2009
      • 1011
      Footnote 1 says when used in item keys, it refers to interface ips. Should that be just HOST.IP without the n?
      • Semiadmin
        • Oct 2014
        • 1626
        I suppose footnote 1 doesn't say anything about a macro numeric index.
