disk drive not showing
  • Anakin05
    • Nov 2021
    Hi there, i configured a trigger for my linux disk space utilization. The trigger works fine but it is not showing my disk drive even after putting the (#fsname) on my title, below is what i use to display the alert,
    {#FSNAME}: Disk space is critically low (used > {$VFS.FS.PUSED.CRIT:"{#FSNAME}"}%)
  • prakashxd
    • Apr 2022
    I searched a similar problem and just signed up so that I can get updated on the issue. It is similar to disk space utilization..
    • Juamanix
      • Apr 2022
      I recommend you clear the disk and run the registry cleaning programs.
        cyber commented
        Oh really? Do you have other good irrelevant recommendations?
    • Juamanix
      • Apr 2022
      In most cases, this problem appears because the game got installed on the different parts of your disk, so the system is trying to settle the information going from the different disk parts. For example, you can run the raid recovery service software at an online service. If you get any other topic-related services, feel free to send a private message to me, I will be glad to help.
