lmsensors working in shell but not in Zabbix
  • cyrj
    • Aug 2006
    I'm using Suse 10.1 AMD64. I've been struggling to get the Temperature functions working.
    Q1: I'm able to type sensors in a shell and get great information about my board, etc. but I can't get Zabbix to see it?
    Q2: Do you need lmsensors to be working on the server side to measure a client?
    I've been googling about... cant find anyone else having this problem recently.
    Thanks in advance,
    Jon
  • Parsec
    • Jan 2007
    Did you ever figure this out?
    I recently started with Zabbix and am wondering about this too. All I get is "Not Supported" yet they are there and work locally.
    • sbadger
      • Dec 2005
      • 81
      Are you able to run lmsensors as the zabbix user?
      • RNHurt
        • Dec 2007
        I don't know if you solved this already, but you might want to check out this post for more information on the problem and a possible solution.
