monitor webservice (soap) by Zabbix
  • starless_boi
    • Aug 2013
    Hi every one
    I want to monitor a soap web service from my Zabbix server.
    from different posts, and following link:
    I got sure that this feature is possible from version 2.4 onward,But could not find a practical sample.
    in detail, what I want is to call a asmx page that contains a series of a web services, along with the request I want to send a xml body like:
    <soap:Envelope xmlns:soap="http://www.w3.org/2003/05/soap-envelope" xmlns:test="http://xxxx.xx/">
    <soap:Body>
    <test:getActiveServices>
    <!--Optional:-->
    <test:username>xxxx</test:username>
    <!--Optional:-->
    <testassword>xxxxxxxx</testassword>>
    </test:getActiveServices>
    </soap:Body>
    </soap:Envelope>
    and get response from web service to compare it with a specific string. (I did this successfully by postman).
    as a workaround, I put the body (above xml) in variable field.
    btw, I added Content-Type: application/soap+xml in headers field.
    but the results was failure.
    after viewing log files, I sow following:
    In httpmacro_append_pair() pkey:'<soap:Envelope xmlns:soap' pvalue:'"http://www.w3.org/2003/05/soap-envelope" xmlns:test="http://xxxxx.xx/">'
    14649:20160118:152914.299 httpmacro_append_pair() "<soap:Envelope xmlns:soap" not enclosed in {}
    14649:20160118:152914.299 End of httpmacro_append_pair():FAIL macro:'(null)'='(null)'
    14649:20160118:152914.299 End of http_process_variables():FAIL
    can you help me,how to add variable, or where to add my request body? this could be very useful if we can do this by Zabbix.
    thanks in advance
  • sperr0w
    • Oct 2014
    • 44
    +1, I have the same task.
    I need to get data from SOAP web service in post request.
    I know about integration of zabbix and SOAPUI, but I expect to find native monitoring.
    Is it possible?
    • perez89
      • Dec 2016
      question
      I would like to have the same answer.
      At this moment I'm trying to monitor a SOAP web service, but I cant figurate the right way to do it.
      Can anyone help me?
      thanks!
      • juan.mottini
        • Feb 2018
        Can anyone help me?
        thanks!
        Same here. Any luck finding a way?
