Interface Discovery regex filter
  • axlrod
    • Dec 2015
    I'm getting really frustrated now, I created a regex to match cisco or HP equipment interface names that I care about:
    ^.*Ethernet[\d][\/][\d].*$|^\w\d{1,2}$
    Feel free to play around here:
    Explore and test this PCRE (Legacy) regular expression online. Understand the pattern with regex explanations, generate code, and export matches to CSV or JSON.
    It basically matches any interface that has
    Cisco: xEthernetx/xxx
    OR
    HP: A1 - XX or 1-XX
    This works fine on my regex tester.. but when I add it to zabbix in the global regex, it complaints:
    Incorrect regular expression "^.*Ethernet[\d][\\/][\d].*$|^\w\d{1,2}$": "Unknown modifier ']'"
    Oookay.. it did an escape on my escape delimiter ??
    So I remove the escape I have on /
    ^.*Ethernet[\d][/][\d].*$|^\w\d{1,2}$
    And it tests ok on all my tests in Zabbix regex tester..
    But I get nothing discovered..
    My discovery filter:
    My global Regex:
    What am I doing wrong??
  • herta
    • Sep 2011
    • 101
    Try putting it in braces:
    ^(.*Ethernet[\d][\/][\d].*$|^\w\d{1,2})$
    • axlrod
      • Dec 2015
      I've added 2 rules where I expect them to return false instead.. this simple regex seems to work..
      ^.*Ethernet0$
      Null|StackPort|loopback|management|vlan
      Your rule again seems to work like mine did, but I haven't tested it.
