Hi
I'm trying to set up monitoring for a HP Proliant DL380-Gen8 and two Proliant DL-380-Gen6 Servers. I can successfully query the servers using ipmitool with this command:
When I create an item for the values, I'm getting unplausible results, for example, I'm getting 2 Watts as a value for the item "Power Meter".
I've successfully set up ipmi-monitoring for a number of fujitsu primergy servers, so I think there is something wrong wich is specific for the HP servers, but I have no idea what the problem is.
I'm using zabbix 2.4.7, the firmware for the HP ILO is up to date.
Can somone tell me what I'm doing wrong here?
Edit:
It lookes like only the temperatures are working correctly: Any other item gets values like "1%" for fans, 2Watts for the PSU Output and so on.
kind regards,
errorsmith
#$ ipmitool -H xx.xx.xx.xx -I lanplus -U Monitoring -P Password sensor ... ... 36-PCI 2 Zone | 38.000 | degrees C | ok | na | na | na | na | 65.000 | 70.000 37-System Board | 37.000 | degrees C | ok | na | na | na | na | 70.000 | 75.000 38-System Board | 35.000 | degrees C | ok | na | na | na | na | 70.000 | 75.000 39-Sys Exhaust | 31.000 | degrees C | ok | na | na | na | na | 70.000 | 75.000 40-Sys Exhaust | 33.000 | degrees C | ok | na | na | na | na | 70.000 | 75.000 41-Sys Exhaust | 33.000 | degrees C | ok | na | na | na | na | 64.000 | 69.000 42-SuperCAP Max | 20.000 | degrees C | ok | na | na | na | na | 65.000 | 0.000 Power Meter | 146 | Watts | ok | na | na | na | na | na | na ... ...
Edit:
kind regards,
errorsmith
