Fake disk alert
  • yatta
    • Feb 2022
    • 82
    Fake disk alert
    I created an "High disk usage" Item and trigger like below;
    After that Zabbix created an alert and I can see on the "Problems" page..
    But if I check on the server with "df -hl" command, there is no "/usr/sap" filesystem on the server!
    Why Zabbix created an alert if there is no fs?
    Thanks!
  • Answer selected by yatta at 22-04-2022, 13:20.
    max.
    • Apr 2022
    • 40
    Hello yatta,
    Zabbix will show the space used in the file system where the specified directory its located.
    For example if you create an item with the key vfs.fs.size[/etc/zabbix,pused] and /etc directory is not mounted in a separate file system then the ouput will be the space used for the root directory /
    Regards
    • max.
      • Apr 2022
      • 40
      Hello yatta,
      Regards
      • yatta
        • Feb 2022
        • 82
        Thanks Max!
