Zabbix trigger configuration
  • MrUrielMcFly
    • Apr 2022
    Hi everyone.
    I have set up a trigger, this trigger notifies me through Telegram, but the alarms are sometimes recover in milliseconds or sometimes in seconds. The problem is: How can I configure the zabbix trigger to send notifications only when mmm in 5 minutes, for example, I don't have the recovery, but if the alarm is resolved in that time, don't send anything?
    I use the Zabbix web app to create the item, and the item reads an ambari-log of a node's state.
    I tried using the count() trigger function and an action that waits 3 minutes to send a notification. Then if the alarm is resolved I only have that notification there is no problem notification but in that solution my problem was with the recoveries in milliseconds because I think the zabbix element can't read that fast so it reads the problem but not the resolution, so I have to close manually. And sometimes the resolve log came first in the item. And to give context I have two items because one reads the "CRITICAL" in the log and the recovery item reads the "OK" in the log.
    Again... Using different item in recovery expression... That is a slippery slope... It may work in some cases, but picking lines out of a logfile with 2 items and expect this to work... nope...
    Recovery expression is additional, it is considered only after your problem expression has turned false. It is not an expression to close the problem. Recovery expression works well in cases described in manual, like filesystem issues, where you may want to trigger on some level (ie 70%), but rearm, when it is on some lower level (like 50%)...
    • MrUrielMcFly
      • Apr 2022
      Thanks for your recommendation, then for my particular problem, how you recommend to board it?
