MSSQL monitoring
  • tonyxavierj
    • Apr 2022
    MSSQL monitoring
    Hi
    We have recently installed Zabbix. we are able to montor our MSSQL DB. I am trying to monitor the number of active sessions. tried adding an item, but unable to get the output.
    the tsql script is
    SELECT COUNT(*)[Active-Users] from [Active Session]
    it gives output in MSSQL management studio. but I dont know how to get this output in Zabbix.
    tried editing the existing MSSQL performance counters template, but that did not work
  • max.
    • Apr 2022
    • 40
    Hello tony, you can configure the odbc connection to your sql server and perform the query in a database monitor item type.
    Regards
