Zabbix3.0beta1 Web Frontend error 500
  • abovebeyond
    • Dec 2015
    • 32
    Hi , trying to install Zabbix3 beta 1
    getting the following error
    [Sun Jan 24 15:53:02 2016] [error] [client XXX] PHP Parse error: syntax error, unexpected '[' in /var/www/html/zabbix/index.php on line 29
    how can i solve it?
    Thanks !
  • Atsushi
    • Aug 2013
    • 2028
    Probably version of PHP is old.
    Please try to use PHP 5.4 or higher.
    Manual:
    • abovebeyond
      • Dec 2015
      • 32
      Thanks ! tried to install php 5.6 but getting the following error
      Error: php56w-common conflicts with php-common-5.3.29-1.8.amzn1.x86_64
      how do i solve it?
      • Atsushi
        • Aug 2013
        • 2028
        Please try remove php-common package and install php56w-common package.
        • abovebeyond
          • Dec 2015
          • 32
          Thanks Atsushi
          have few more issues:
          At least one of MySQL, PostgreSQL, Oracle, SQLite3 or IBM DB2 should be supported. (i installed and configure zabbix DB using the following tutorial:
          PHP gd extension missing (PHP configuration parameter --with-gd).
          PHP gd PNG image support missing.
          PHP gd JPEG image support missing.
          PHP gd FreeType support missing.
          Thanks , appreciate your help
          • Atsushi
            • Aug 2013
            • 2028
            What dbms your installed?
            MySQL? PostgreSQL?
            If you use MySQL, I think php56w-mysqlnd is needed.
            If you use PostgreSQL, I think php56w-pgsql is needed.
            And, are you installed php56w-gd, php56w-bcmath, php56w-pdo, php56w-xml and php56w-mbstring?
            • abovebeyond
              • Dec 2015
              • 32
              thanks the php56w-mysqlnd solved the first problem
              what about the php gd errors?
              • Atsushi
                • Aug 2013
                • 2028
                Do you installed php56w-gd package?
                Do you restart Web server?
                • abovebeyond
                  • Dec 2015
                  • 32
                  i needed to reboot the server for some reason
                  its working now
                  thanks !!
