Convert mib files to zabbix template ?
  • aldms1126
    • Sep 2021
    • 14
    Is it possible to convert the mib file to zabbix template?
    When I use mib2zabbix, it doesn't convert normally.
    The SNMP OID value appears normally when responding with snmpttranslate, but when piped to mib2zabbix, the template seems to be created referring to other mibs.
    When I read the mib file in snmpptTranslate,
    [root@mgmt_cdp Alteon]# snmptranslate -Tz -m ./ALTEON-CHEETAH-LAYER4-MIB.mib
    "org" "1.3"
    "dod" "1.3.6"
    "internet" "1.3.6.1"
    "directory" "1.3.6.1.1"
    "mgmt" "1.3.6.1.2"
    "experimental" "1.3.6.1.3"
    "private" "1.3.6.1.4"
    "enterprises" "1.3.6.1.4.1"
    "alteon" "1.3.6.1.4.1.1872"
    "registration" "1.3.6.1.4.1.1872.1"
    "aceswitch110" "1.3.6.1.4.1.1872.1.1"
    "acedirector" "1.3.6.1.4.1.1872.1.2"
    "aceswitch180" "1.3.6.1.4.1.1872.1.3"
    "acedirector2" "1.3.6.1.4.1.1872.1.4"
    "aceswitch180e" "1.3.6.1.4.1.1872.1.5"
    "acedirector3" "1.3.6.1.4.1.1872.1.6"
    "cachedirector" "1.3.6.1.4.1.1872.1.7"
    "gs-switches" "1.3.6.1.4.1.1872.1.8"
    "chas-switch" "1.3.6.1.4.1.1872.1.8.1"
    When the snmpttranslate data is piped into mib2zabbix,
    snmptranslate -Tz -m ./ALTEON-CHEETAH-LAYER4-MIB.mib | ./mib2zabbix -o .1.3.6.1.4.1 -f template-alteon_layer4-mib.xml -N Alteon_LAYER4-mib
    If you check the SNMP OID of template-alteon_layer4-mib.xml,
    <snmp_oid>.1.3.6.1.4.1.2021.16.2.1.101.{#SNMPINDEX }</snmp_oid>
    When responding with snmpttranslate,
    It normally responds with 1.3.6.1.4.1.1872.x, but if it is piped with mib2zabbix, it returns 1.3.6.1.4.1.2021.x. Is there a way to convert a template to a normal OID?
  • serkanbaybuga
    • Jul 2022
    Did you find the solution?
    Regards
    • mk.hasan
      mk.hasan commented
      I am also getting same problem. Did you solve it ?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    You could try this one https://sbcode.net/zabbix/mib-to-zabbix-template/
    • Yafimm
      • May 2022
      • 9
      Yes, it is possible to convert a MIB file to a Zabbix template. MIB (Management Information Base) files contain definitions of objects that can be monitored by an SNMP (Simple Network Management Protocol) agent. Zabbix is a monitoring tool that can use SNMP to monitor devices on a network and display the collected data in the form of charts and graphs.
      To convert a MIB file to a Zabbix template, you can use a tool called mib2zabbix, which is a command-line tool that converts MIB files to Zabbix templates. However, if you are experiencing issues with mib2zabbix not converting the MIB file correctly, there are a few things you can try:
      1. Make sure you have the required dependencies installed: mib2zabbix requires Python and the PySNMP library to be installed on your system.
      2. Check the MIB file for errors: MIB files can be complex and may contain errors that prevent them from being parsed correctly by mib2zabbix. Use a MIB parser tool to check the MIB file for syntax errors and fix any issues you find.
      3. Use the -v option to increase the verbosity of the mib2zabbix output: This can help you identify any errors or issues that may be occurring during the conversion process.
      4. Make sure you have the correct MIBs installed: mib2zabbix may refer to other MIBs that are not installed on your system. In this case, you will need to find and install the missing MIBs in order for the conversion to be successful.
      If you are still having issues with mib2zabbix after trying these suggestions, you may want to consider using an alternative tool or method for converting MIB files to Zabbix templates. There are other tools and scripts available that may be able to help you with this task.
      • irontmp
        • Sep 2023
        • 98
        mib2zabbix doesn't actually use the piped snmptranslate text, it loads MIBs through Net-SNMP's own resolver based on your MIB path, not what's printed in the terminal. The OID 1.3.6.1.4.1.2021 belongs to UCD-SNMP-MIB, so it's likely picking up a name collision with a system loaded MIB instead of your local Alteon file. Try setting MIBDIRS and MIBS explicitly before running it so only your Alteon MIB and its dependencies are visible, for example export MIBDIRS=/usr/share/snmp/mibs:/path/to/Alteon and export MIBS=+ALTEON-CHEETAH-LAYER4-MIB, and if mib2zabbix still struggles, a tool like AhaConvert might handle the conversion more reliably since it can take the MIB file path directly. If it still resolves incorrectly after isolating the path, you may need to manually patch the generated XML or use a different tool that takes the MIB file path directly rather than piped output.
