Hi All,
I am using the Fortinet Interaces template from https://github.com/jjmartres/Zabbix/...net-interfaces and I noticed that it has temaplate discovery triggers based on the utilization of the interface speed.
However we do not want the interface utilisation trigger to be based on the interface speed, as in the case of interfaces used for internet connection, the bandwidth provided by an ISP is in our case always lower than the interface speed. We want the trigger to be based on a Macro value that we will enter on the host manually. I have done the host level macro and host level trigger and they work well.
Is there anyway we can put this in the template so it will create macros with blank values for us to fill in on a host based on all the discovered interfaces?
