Zabbix server VPS more/less Proxy VPS? Possible
  • gbiondi
    • Nov 2016
    • 75
    Hi at All,
    I have a zabbix server V5.0.23 and 3 Click image for larger version
Name:	Immagine 2022-05-10 182134.jpg
ID:	444356 proxies with different load between them .. doing a dashboard to check the effort of the proxies it seems that all have the same VPS values ... in my opinion it is not possible .. don't you think?
    Having 3 proxies with same load is ok. But your server number should be about the sum of those...
    • gbiondi
      • Nov 2016
      • 75
      ... I also thought so .. but it is not so .. it could be a bug .. moreover the 3 proxies do not have the same load ..
