zabbix monitor weblogic
  • qd_056
    • Jan 2016
    hello together
    when I tried to monitor my weblogic performance via zabbix, I encountered below issues:
    1: failed to link the template - Template JMX Generic, below error shows:
    Cannot find host interface on "servername" for item key "jmx["java.lang:type=ClassLoading",LoadedClassCount]".
    is this due to the JMX enable failure issue on weblogic side?
    I added below JAVA_OPTIONS to $DOMAIN_HOME/bin/setDomainEnv.sh file and restart weblogic already.
    JAVA_OPTIONS=”${JAVA_OPTIONS} -Djava.rmi.server.hostname=myserver hostname of weblogic installed”
    JAVA_OPTIONS=”${JAVA_OPTIONS} -Djavax.management.builder.initial=weblogic.managem ent.jmx.mbeanserver.WLSMBeanServerBuilder”
    JAVA_OPTIONS=”${JAVA_OPTIONS} -Dcom.sun.management.jmxremote=true”
    JAVA_OPTIONS=”${JAVA_OPTIONS} -Dcom.sun.management.jmxremote.port=12345”
    JAVA_OPTIONS=”${JAVA_OPTIONS} -Dcom.sun.management.jmxremote.ssl=false”
    JAVA_OPTIONS=”${JAVA_OPTIONS} -Dcom.sun.management.jmxremote.authenticate=false”
    export JAVA_OPTIONS
    one more question is, the java-gateway should be installed on my weblogic server side, not on zabbix server, right?
    Thanks in advance for your help.
  • Colttt
    • Mar 2009
    • 878
    you must add an IP for ypu JMX interface!
    Debian-User
    Sorry for my bad english
    • qd_056
      • Jan 2016
      Thanks for your reply and how $ where to add the IP?
      • qd_056
        • Jan 2016
        update - JMX was enabled
        update:
        with the help from Oracle guys, the JMX on weblogic server is enabled already.
        But on ZABBIX side, still failed to link Template JMX Generic.
        And there also below error log while I created item for weblogic server with Type options = "JMX Agent"
        error:
        Host interface No interface found
        • qd_056
          • Jan 2016
          Latest Update
          Latest Update:
          Template was linked successfully and I am able to create item with type = JMX agent
          but the JMX icon is RED and shows "cannot connect to servername:10052 [111] connection refused"
          the java-gateway was installed on weblogic server and listening port 10052
          tcp 0 0 *:10052 *:* LISTEN
          looks like I almost get there, hopefully someone can help.
          Thanks in advance
          • Bruno Carvalho
            • Oct 2014
            • 32
            See my article: http://brunocarvalho.net/blog/2016/0...me-com-zabbix/
