Error in Problems
  • JulioQc
    • Dec 2018
    • 28
    Error in Problems
    I get this error when I navigate to Problems:
    preg_match(): Unknown modifier '0' [jsrpc.php:90 → CScreenProblem->get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver->resolveTriggerNames() → CMacrosResolver->resolveTriggerExpressions() → CMacrosResolverGeneral->getUserMacros() → CMacrosResolverGeneral->getHostUserMacros() → preg_match() in include/classes/macros/CMacrosResolverGeneral.php:1340]
    Is there a way for me to track it down to the faulty item/template/trigger that causes this? Seems like a macro but which one?
    Thank you!
    And your environment is... ? versions etc...
    • JulioQc
      • Dec 2018
      • 28
      Ya sorry that's Zabbix 5.4.10 on Ubuntu 20.04 and MySQL 8.0.28
        PHP7? 8? If by accident its 8, then its not supported...
        • JulioQc
          • Dec 2018
          • 28
          True, I get 7.4.3 for php -v
          • JulioQc
            • Dec 2018
            • 28
            Any ideas how to track this to the specific template/host/item?
            Issue persist after going to Zabbix 6.2.0
            • JulioQc
              • Dec 2018
              • 28
              Ok found how to track after noticing the error comes and goes from the dashboard: go to problems, filter to history instead of recent/problems, narrow the time frame until you see the PHP error show up and only a few hosts are listed (I had to narrow to a single minute), filter out host by host until you find which one triggers the alert.
              From there, check your macro values for issues. I my case:
              Macro: {$IFCONTROL:regex:"^(Gi[1-4]\/0\/(1[3-9]|[2-3][0-9]|4[0-8]))$"}
              Value: 0
              Find the issue. If regex is true, value is 0 and no error. If regex is false, value is 1 (default from template {$IFCONTROL}) but PHP error is shown.
              The whole thing works to exclude some "unimportant interfaces" so I believe this is only cosmetic.
              I hope this gets resolve but I doubt it will without proper support ticket. I hope it helps someone else chasing this issue
