Trigger for File older than 7 days
  • lovezabbixaj
    • Jan 2016
    • 9
    I want to implement a trigger , if a file on my system is older than 7 days. I have been investigating on key vfs.file.time[file,<mode>]. But the modes available here are modify,access and change. How can create a trigger which is based on file creation timestamp? Please provide pointers.
    Thanks.
  • Colttt
    • Mar 2009
    • 878
    normally in Linux it dont exist a "create" field for files, so can can query that..
    Debian-User
    Sorry for my bad english
    • lovezabbixaj
      • Jan 2016
      • 9
      Looking for windows help
      Thanks for your reply.
      I am implementing this for windows where we do have creation date
      If anyone has any idea how to implement this plz help.
      • lovezabbixaj
        • Jan 2016
        • 9
        Difference between modify and change mode?
        What is the difference between modify and change mode in key vfs.file.time[file,<mode>] ?
        • lovezabbixaj
          • Jan 2016
          • 9
          How to Windows?
          OK I got answer for my previosu question.
          There is access time - the time that someone (reads) look in document.
          There is modify time - the time that file is modified, appended, writed or rewrited
          There is change time - the last time meta data of the file was changed (e.g. permissions)
          So now only question left unanswered is can we check file creation timestamp for a file on windows?
