Remote command not executed on agent
  • Manish
    • Jan 2016
    • 27
    Hello there,
    I have problem with remote command. I created action if disk in critical state then make log file zero byte. On event it shows command executed but actually its not disk still in problem state. I had to log in on to the server and truncate file to zero byte. I wonder why this happned? I given sudo permission to zabbix user for truncate command as well.
    Here is summary:
    Action condition: Trigger value = PROBLEM and Trigger = Template xxx: / Disk Critical.
    Operation command: truncate -s 0 /path/to/file.
  • Atsushi
    • Aug 2013
    • 2028
    Are you set to remote command execution allowed by the setting of the agent?
    ex. zabbix_agentd.conf
    EnableRemoteCommands=1
    User zabbix has write access to the file?
    • Manish
      • Jan 2016
      • 27
      Yes, I already set it to 1. Does zabbix user need write access to log file?
      • Atsushi
        • Aug 2013
        • 2028
        By default, the agent has been started by zabbix user.
        Thus, the remote command is executed by zabbix user.
        If there is no write permission, truncate can not be run on the file.
        If you do not want to change the permissions of the file, please try to use sudo.
        • Manish
          • Jan 2016
          • 27
          Hi Thanks.
          I used sudo and its working now. However I have another problem. I am using zabbix version 2.4.7 and I set above condition to delete old logs. I want to use this command on several host, so in target section of operations I selected all the host where I want to execute this command.
          But problem is when only one host have problem command executed on all other host and delete its log. So do I want to set action for each and every host separatly?
          • Atsushi
            • Aug 2013
            • 2028
            Please try select target "Current host" only.
