Low Level Discovery (LLD) Disable VNETx Devices
  • riaanp
    • Mar 2019
    • 9
    Good day,
    I am wondering if someone can point me in the right direction.
    I am aware that you can filter/remove certain devices from LLD, I am just not sure how that is done exactly. I am trying to remove all VNET devices from all my hosts since they report their speeds wrong and generate a massive amount of alerts.
    Anyone have proper steps to do this?
  • max.
    • Apr 2022
    • 40
    Hello, how are you?
    You can use the filter tab in the discovery object to match specific macro with value or regex.
    Regards
    • riaanp
      • Mar 2019
      • 9
      Hi, good thanks
      Originally posted by max.
      Hello, how are you?
      Regards
      Is this per host or global? Really looking for a global option
      And have documentation about the subject with a working how to possibly?
      • riaanp
        • Mar 2019
        • 9
        When I go here: Templates -> All templates -> Linux by Zabbix agent then i click macros and then i scroll down I see:
        {$NET.IF.IFNAME.NOT_MATCHES}
        and the values are:
        (^Software Loopback Interface|^NULL[0-9.]*$|^[Ll]o[0-9.]*$|^[Ss]ystem$|^Nu[0-9.]*$|^veth[0-9A-z]+$|docker[0-9]+|br-[a-z0-9]{12})
        Would it be the right approach to just add another regular expression there to exclude? For example:
        (^Software Loopback Interface|^NULL[0-9.]*$|^[Ll]o[0-9.]*$|^[Ss]ystem$|^Nu[0-9.]*$|^veth[0-9A-z]+$|^vnet[0-9A-z]+$|docker[0-9]+|br-[a-z0-9]{12})
        • max.
          • Apr 2022
          • 40
          Yes, that should work, it seems that the discovery already has a filter that matches the regex macro!
          Regards
