Remote Command option missing from Action operations
  • LenR
    • Sep 2009
    • 1011
    I just noticed that my 6.0.3 doesn't seem to have the option for remote command in action operations. Is there some config setting to enable this on the server? I know I would have to enable it in the agent, but I'm just looking at the config now.
  • Atsushi
    • Aug 2013
    • 2028
    Try registering the remote command you want to execute in the global script. If you do not register, you can only select "Send message" as an action operation.
