First off many thanks for making Zabbix freely available, it really is an excellent monitoring system that has saved our bacon on numerous occasions.
I want to upgrade from 2.0.6 to 2.2.9. I though it would be a good idea to build a new Zabbix server and a new Mysql Server to make fresh start so to speak.
In order to get a nice smooth upgrade I want to get our 2.0.6 system running on the new hosts and then execute the upgrade to 2.2.9 on the new hosts.
The original system is running CentOS 6 with Mysql v 5.1.68.
The new system is the same but with MySQL v 5.1.73
I made a dump of the mysql and zabbix databases and imported them into the new MySQL system without any errors
I then installed
zabbix-2.0.6-1.el6.x86_64.rpm
zabbix-java-gateway-2.0.6-1.el6.x86_64.rpm
zabbix-server-2.0.6-1.el6.x86_64.rpm
zabbix-web-2.0.6-1.el6.noarch.rpm
zabbix-agent-2.0.6-1.el6.x86_64.rpm
zabbix-sender-2.0.6-1.el6.x86_64.rpm
zabbix-server-mysql-2.0.6-1.el6.x86_64.rpm
zabbix-web-mysql-2.0.6-1.el6.noarch
on the new zabbix server along with Apache, PHP and php-ldap
Finally I copied over zabbix_server.conf and edited this to point at the new MySQL server.
The first time I started the new system up I got the initial configuration screen. Clicking through this showed the system was configured correctly. The database Test Connection was successful with the credentials I supplied.
Here is the php-ldap info:
# rpm -q php-ldap
php-ldap-5.3.3-46.el6_6.x86_64
The problem is when I try to login I get the "Probably php-ldap module is missing" error message
Looking in the zabbix server log I can see it is polling hosts and generally doing what it ought to.
I suspect I'm made a trivial mistake but I would be grateful for some pointers
Shaun
I then installed
# rpm -q php-ldap
Shaun
