Can I receive notifications if I have a problem for disk space on a Linux machine ?
  • zurattos
    • May 2022
    Hello ,
    I want to ask a question can I configure Zabbix to receive a notification once there is a problem in the disk space of any Linux machine ?
    Best Regards
  • tim.mooney
    • Dec 2012
    • 1436
    Yes.
    Look at the vfs.fs.size and the various possible modes (pfree for % free, pused for %used, as well as free and used): https://www.zabbix.com/documentation...le-system-data
    Look at "Example 2" in the "Hysteresis" section for an example of configuring thresholds (triggers): https://www.zabbix.com/documentation...ers/expression
    You can also look at some of the built-in templates, there's a lot you can learn from reviewing those.
