SNMP Config / Testing help
  • Wayne
    • Oct 2006
    • 27
    Hi guys,
    We are trying to setup Zabbix to monitor one of our main switches. I have enabled SNMP, created the user/community/auth passphrase/priv passphrase on the switch.
    Zabbix is not graphing data. So I figured the next logical step is to check that output on the switch is correct.
    I have tried the following command on the zabbix server:
    snmpwalk -v 3 -c mycommunityname <IP address of switch>
    but I receive the following error:
    snmpwalk: Failure in sendto (Operation not permitted)
    I have googled the error, but everything I came up with wasn't in English
    Does anyone have experience setting up SNMP monitoring that could help me out just a bit?
    Any help is appreciated!
  • johanpre44
    • Apr 2006
    • 40
    Using snmpwalk utility to test SNMP
    I'm using SNMP, but only versions 1 and 2c. When I test SNMP I use the following command:
    snmpwalk -Os -v 1 -c <community_string> <host> [section]
    <community_string> = your community string, this is usually public
    <host> = your host name or ip
    [section] = This is optional and i usually use "system" or "interfaces",
    basically this just cuts down on the ammount of info returned
    -v 1 = the version, can be changed to "-v 2c", but with "-v 3" you need a username/password or something (think it with this you need the -A, -a, -u, -x, -X switches - see "man snmpcmd" for more help - I don't have any v3 SNMP to test this with)
    If I want to get and output that I can use in zabbix I will use
    snmpwalk -Of -v 1 -c <community_string> <host> [section] | cut -d "." -f 8-50
    the output:
    interfaces.ifNumber.0 = INTEGER: 9
    interfaces.ifTable.ifEntry.ifIndex.1 = INTEGER: 1
    interfaces.ifTable.ifEntry.ifIndex.2 = INTEGER: 2
    The part before the "=" can then be used straight in zabbix
    Also check your zabbix_server log file, I forgot to compile with SNMP support and only noticed when I had a look at the log file...
    I prefer to stick to SNMP v1 because most of the Cisco routers and 3com switches on my network supports it. I also cannot see the difference between v1 and 2c when I do and snmpwalk, the informations returned is the same for both.
    • Wayne
      • Oct 2006
      • 27
      Awesome. Thank you for the info, I will be doing some testing on that today and see what we can come up with.
      Thanks!
