Dear Friends,
Just registered to the zabbix forum
and joined to you.
I have a bit urgent and quick question;
I use SMS API as, "/usr/bin/curl "http://xxx"$1"&Messages="$2"&TransmissionID=XXX"
i check with "logger" command and notice that script does work but does not send SMS to the relate SMS numbers. But, whenever i change the scvript and use without parameters and directly write the numbers into the script then it Works.
as far as i understood, there is a problem related SMS API script of the ZABBIX, but could not find it.
anyone has any idea please ?
Best Regards,
Cemal,
and joined to you.I have a bit urgent and quick question;
Best Regards,
Cemal,
