How add trigger dependency in version LTS 6.0
  • mzeman81
    • Dec 2020
    • 27
    Please can you help me how could I add trigger dependency if I map to the host an template for example "ICMP Ping"?
    The old procedure does not work in new Zabbix 6.0 LTS version.
    Many thanks for any help.
  • Hamardaban
    • May 2019
    • 2714
    Release Notes for Zabbix 6.0.5 https://www.zabbix.com/release_notes
    ZBX-20613 Returned the ability to edit the dependencies of inherited triggers; improved validation upon unlinking templates with triggers that have dependencies; improved performance of trigger dependency functionality; prevented the ability to fully replace trigger dependencies of inherited triggers if the new dependency was added to parent trigger; supplemented validation of trigger dependencies on templates to prevent linkage dead-ends
    • mzeman81
      • Dec 2020
      • 27
      OK, and I can you advice and show some example how to add dependency in LTS 6.0.?
      Many thanks
