Problem with zabbix report generator
  • dinao
    • Apr 2020
    • 9
    I'm currently setting up the report generator in zabbix and it was pretty straight forward until i hit a roadblock.
    I have a lot of troubles setting up the SSL. When i try to do it i have this error that is popping up :
    2022/06/02 15:42:57.150791 starting Zabbix web service
    2022/06/02 15:42:57.151015 failed to start: failed to read CA cert file: open /etc/letsencrypt/live/MYDOMAIN/fullchain.pem: permission denied
    2022/06/02 15:43:07.211632 starting Zabbix web service
    2022/06/02 15:43:07.211790 failed to start: failed to read CA cert file: open /etc/letsencrypt/live/MYDOMAIN/fullchain.pem: permission denied
    If i try to enable IgnoreURLCertErrors=1 i get this :
    2022/06/02 15:23:28.031852 starting Zabbix web service
    2022/06/02 15:41:01.549573 received report request from MY_IP:61494
    2022/06/02 15:41:01.549697 Method is not supported.
    My SSL certificate is generated with certbot, but it looks like there is a permission issue with the cert files. This link /etc/letsencrypt/live/MYDOMAIN/fullchain.pem and all the files in this folder are symlinks pointing to /etc/letsencrypt/archive/MYDOMAIN/
    root@zabbix:~# ls -la /etc/letsencrypt/live/MYDOMAIN/
    total 12
    drwxr-xr-x 2 root root 4096 26 mai 01:08 .
    drwx------ 3 root root 4096 1 avril 2020 ..
    lrwxrwxrwx 1 root root 41 26 mai 01:08 cert.pem -> ../../archive/MYDOMAIN/cert14.pem
    lrwxrwxrwx 1 root root 42 26 mai 01:08 chain.pem -> ../../archive/MYDOMAIN/chain14.pem
    lrwxrwxrwx 1 root root 46 26 mai 01:08 fullchain.pem -> ../../archive/MYDOMAIN/fullchain14.pem
    lrwxrwxrwx 1 root root 44 26 mai 01:08 privkey.pem -> ../../archive/MYDOMAIN/privkey14.pem
    -rw-r--r-- 1 root root 692 1 avril 2020 README
    If i go in /etc/letsencrypt/archive/MYDOMAIN/ i get this :
    root@zabbix:~# ls -la /etc/letsencrypt/archive/MYDOMAIN/
    total 260
    drwxr-xr-x 3 root root 4096 1 avril 2020 ..
    -rw-r--r-- 1 root root 1846 26 sept. 2021 cert10.pem
    -rw-r--r-- 1 root root 1846 25 nov. 2021 cert11.pem
    -rw-r--r-- 1 root root 1846 25 janv. 11:28 cert12.pem
    -rw-r--r-- 1 root root 1846 26 mars 21:50 cert13.pem
    -rw-r--r-- 1 root root 1846 26 mai 01:08 cert14.pem
    -rw-r--r-- 1 root root 1911 1 avril 2020 cert1.pem
    -rw-r--r-- 1 root root 1911 31 mai 2020 cert2.pem
    -rw-r--r-- 1 root root 1915 31 juil. 2020 cert3.pem
    -rw-r--r-- 1 root root 1915 29 sept. 2020 cert4.pem
    -rw-r--r-- 1 root root 1915 28 nov. 2020 cert5.pem
    -rw-r--r-- 1 root root 1846 28 janv. 2021 cert6.pem
    -rw-r--r-- 1 root root 1846 29 mars 2021 cert7.pem
    -rw-r--r-- 1 root root 1846 29 mai 2021 cert8.pem
    -rw-r--r-- 1 root root 1846 28 juil. 2021 cert9.pem
    -rw-r--r-- 1 root root 3750 26 sept. 2021 chain10.pem
    -rw-r--r-- 1 root root 3749 25 nov. 2021 chain11.pem
    -rw-r--r-- 1 root root 3749 25 janv. 11:28 chain12.pem
    -rw-r--r-- 1 root root 3749 26 mars 21:50 chain13.pem
    -rw-r--r-- 1 root root 3749 26 mai 01:08 chain14.pem
    -rw-r--r-- 1 root root 1647 1 avril 2020 chain1.pem
    -rw-r--r-- 1 root root 1647 31 mai 2020 chain2.pem
    As you can see, the folder has the right rights in order to read the cert files. In order to debug it, i changed to perms to 777 and it didn't change a thing. I also verified all the above folders and there were read rights to "anyone".
    Finally, i tried to skip the SSL completely in order to just make it work, so i changed the frontend url from HTTPS to HTTP and in the serverconf i also changed the url from HTTPS to HTTP. The report sending is working, i get the email in my inbox but when i open the link, i get a 404 because i think that there is a redirect somewhere in my apache vhost config. I didn't wanted to go any further down the HTTP route because it doesn't interest me, i need that functionality with the SSL and i didn't wanted to weaken my security just for this.
    I'm having a really hard time finding documentation or tutorials on how to set up this functionality with SSL.
    Thank you in advance for your help.
    Regards,
