Zabbix Oracle support
  • vardhasu
    • Oct 2015
    • 17
    Hi
    Recently downloaded 2.4.7 source and compiled with oracle after runnin configure --with-oracle ... I have the agent and server up. When I try to run setup.php, oracle database is not recognized in "Check of pre-requites". The line PHP database support shows as off. The oracle server is on another node and not running locally.
    Thanks and Regards
    Vardhan
  • Atsushi
    • Aug 2013
    • 2028
    Are you installed the oci8 module of PHP?
