Error when cloning stock template in 6.05
  • nils2
    • Apr 2011
    • 26
    I've just upgraded from 4.2 to 6.0 LTS (6.05). I've downloaded the original templates from the Zabbix git server, reconfigured some old hosts, etc. I wanted to customize the "Linux by Zabbix agent" template by making a full clone, but I'm always getting the following message:
    Cannot add template
    Invalid parameter "/2/pages/1/widgets/3/fields/2/value": a number is expected.
    Can anyone tell me what's happening? Is this a bug in Zabbix 6.05?
  • Answer selected by nils2 at 11-06-2022, 14:00.
    nils2
    • Apr 2011
    • 26
    Using the very hand utility called `mysql-schema-diff` I compared my upgraded MySQL schema with that of a freshly installed 6.05 server. I made the changes to make them identical, except for the row format (I left all tables as `dynamic`). Et voila, it started to work. I can Full Clone and customize my templates without issues. An interesting tidbit is that only some indices were dropped or created anew on the old schema. Apparently the 6-series installer is a bit sloppy in that regard - or maybe it's intentional so custom DB changes are left intact for the user.
    Special thanks to Markku for keeping up and offering some suggestions.
    • vladimir_lv
      • May 2022
      • 240
      Hi.
      Can you check the template version? Export template and find word "version ".
      • nils2
        • Apr 2011
        • 26
        Hi, see below:
          version: '6.0'
        • Markku
          • Sep 2018
          • 1784
          Trying to establish a baseline first again to make sure I understand what was actually done So do you mean that you
          1. Upgraded Zabbix installation from 4.2 to 6.0.5
          2. Downloaded the "Linux by Zabbix agent" template from git.zabbix.com
          3. Imported it
          4. Attempted Full clone, and before doing anything else you got the error?
          Markku
          • nils2
            • Apr 2011
            • 26
            Yes. It gave the error when clicking "Add" after "Full Clone" and giving it a new name.
            • Markku
              • Sep 2018
              • 1784
              Right. I attempted the same (my Zabbix was just recently upgraded from 5.0.23 to 6.0.5 and doesn't have the Zabbix official templates):
              1. Downloaded the 6.0 template of "Linux by Zabbix agent" (template_os_linux.yaml)
              2. Imported it
              3. "Full clone", gave it a new name, "Add"
              4. Worked for me
              Your error message was referring to "/2/pages/1/widgets/3/fields/2/value", and there are some widgets under dashboards section in the original yaml file. In Zabbix GUI, if you try to modify them somehow, does it affect your "Full clone" attempt?
              Markku
              • Markku
                • Sep 2018
                • 1784
                (Btw in that original yaml file the syntax is partly strange:
                - why is the "y" field single-quoted and others aren't
                - why are integers quoted like strings
                I assume these are some known features of yaml that you can do whatever you like )
                Markku
                • nils2
                  • Apr 2011
                  • 26
                  The yaml indeed looks weird, but correct. It's a fairly lenient format.
                  I tried what you suggested, rearranged the graphs in the "System performance" dashboard and saved it as well, then saved the "Network interfaces" one (without changes as there are no discovered interfaces in a template). Still the same error:
                  Cannot add template
                  Invalid parameter "/2/pages/1/widgets/3/fields/1/value": a number is expected.
                  EDIT: in a freshly installed 6.05 instance cloning works as expected. No errors.
                  • Markku
                    • Sep 2018
                    • 1784
                    Interesting. How is your setup installed, which OS, packages installed and upgraded from official repo? Any special customizations "under the hood", like modified php files, manually edited database, or something like that?
                    After the 6.0.5 upgrade I did the double.sql modification as well as the history index additions. I haven't yet done the post-6.0 utf8mb4 change, the database is originally from some 3.x version (through maybe 3.4, 4.0, 4.4 and 5.0 series). Running on Debian 11 at the moment.
                    (Edit: Using MariaDB, currently the Debian-supplied 10.5.x. At some point I believe I had to do some row format change manually in the database.)
                    Markku
                    • nils2
                      • Apr 2011
                      • 26
                      The setup is unmodified, I only have customized templates on the server itself. I always install the server from the upstream repo, never from the OS-provided packages. Debian 11, MariaDB 10.5, everything is upgraded to latest version. I only made 2 important changes: changed the table type of all tables to dynamic and ran the Zabbix provided (on the upgrade support page) utf8mb4 fix up script after the automatic schema upgrade. It was originally a 3.x setup, upgraded to 4.0, then 4.2 and now to 6.05. This is the first serious issue I've run into with Zabbix server upgrades...
                      • Markku
                        • Sep 2018
                        • 1784
                        Sounds pretty clean then.
                        How about totally deleting the Dashboards from the template (either from yaml before importing or from GUI before Full clone), does it affect the error message?
                        Markku
                        • nils2
                          • Apr 2011
                          • 26
                          That's something I actually wanted to try, but I first need to devise a method to easily put them back. They seem useful so I don't want to just wipe them.
                          • Markku
                            • Sep 2018
                            • 1784
                            One more (maybe not very handy) idea: if you can find the relevant part in the Zabbix sources, it may give a hint where the "invalid parameter" is.
                            I guess opening a support ticket is not useful (unless with paid support), it is highly likely that it will be closed as Cannot Reproduce... but maybe someone else suffers the same.
                            Markku
                            • Markku
                              • Sep 2018
                              • 1784
                              And: "/2/pages/1/widgets/3/fields/1/value" I don't know that the 2 would be but it looks like "page 1, widget 3, field 1" has the invalid value
                              EDIT: Now I see that the error actually changed after you did some edits to the dashboards/widgets: the fields was 2 originally, later it was 1
                              Markku
                              • nils2
                                • Apr 2011
                                • 26
                                #15
                                Good catch. I tried to copy-paste the pages in the dashboards - this worked, I essentially re-created both dashes in the template and removed the old ones. Still the same error. It's nuts.
