Display an items previous value
  • markfree
    • Apr 2019
    • 875
    I would like to display the previous value of an item whenever an event is fired.
    Let's say I have an item that triggers with a value of 0.
    last(/hostname/item.key)=0
    Whenever that trigger is true, the operational data should display the latest and previous values.
    I hoped the syntax was something like this:
    Last value: {ITEM.LASTVALUE} - Previous value: last(/{HOST.HOST}/{ITEM.KEY},#2)
    For that, I tried to use the last() function, but it won't resolve within "operational data".
    I searched for a macro that would display such a previous value, but could not find it.
    Example:
    Trigger
    Event
    Click image for larger version  Name:	testmacro_example.png Views:	0 Size:	10.6 KB ID:	445809
    Any idea?
    • 4993
    This does not work... Operational data supports macros,
    Operational data allow to define arbitrary strings along with macros.
    but you cannot use trigger functions there to modify macro value or even pull completely different value. Customizing macro values is supported only for couple of macros, like {ITEM.VALUE} and {ITEM.LASTVALUE} (https://www.zabbix.com/documentation...acro_functions)
    To resort to usable macros, you are forced to include needed value in your trigger expression (prev(/host/item).... find some function which is always true and does not affect whole calculation) and refer to it in Operational data as {ITEM.LASTVALUE2}.
    • markfree
      • Apr 2019
      • 875
      I thought of using {FUNCTION.VALUE} macro as it actually works with event names, but it does not work with operational data or trigger description.
      Something like this:
      last(/Single/test.macro)=0 and last(/Single/test.macro,#2)
      Maybe {ITEM.VALUE} would work out, but, unless I'm using different items in the trigger expression, I don't see how to do this.
      • fpaternot
        • Feb 2013
        • 52
        Have you guys tried using this?
        find(/template/item,"a")<>2 (yes, it returns 0 or 1, so using "different than 2" works for all possible return values)
        {ITEM.VALUEn} and/or {ITEM.LASTVALUEn} in operational data.
        I've used this hack myself for years.
        I don't see another way to get data there.
        • markfree
          • Apr 2019
          • 875
          Maybe I misunderstood, but I don't think this would work.
          When I try to include something like "find(/Single/test.123,"a")<>2", I get an error when saving the trigger because the function parameter is invalid.
          Invalid parameter "/1/expression": invalid second parameter in function "find".
          If I include the correct parameters, but matching a string, then the trigger gets "not supported".
          Cannot evaluate function find(/Single/test.123,#2,"like","test"): operator "like" is not supported for counting numeric values.
          Unless I know the item value range, I cannot match a number to avoid false positives. However
          ​, with a known value range, I can use the find function to match something other than 0 or 1. This can actually trigger an event.
          Still, I can't display the previous value in the operational data field.
          In this example, the previous value should be "10".
            • 4993
            ITEM.VALUE2 refers to the last value of the second used item... but you are using one item twice...So you get same value twice...
            Expression macros? Too lazy to test myself..
            last - {?last(/Single/test.123)} - previous {?last(/Single/test.123,#2)}
            • markfree
              • Apr 2019
              • 875
              I tested with expression macros, but they are not supported on the operational data field.
              • uniken1
                • Sep 2012
                • 100
                Hello, I have same question. Do you solve this?
                • uniken1
                  • Sep 2012
                  • 100
                  As workaround I found only one way.
                  My task is check when Total Memory of server changed show amount of changes.
                  I created secondary "Calcuated" Item from first Total Memory with last(//vm.memory.size[total]), preprocessing "Discard on change with heartbeat" and history 1d
                  My trigger configuration:
                  Operational data: Prev: {ITEM.LASTVALUE2} New:{ITEM.LASTVALUE1}
                  Expression: last(/test14/vm.memory.size[total]) < max(/test14/vm.memory.size.total.secondary, 1d)
                  Now I receive Previous and Last value of Total memory
                  • Alex Robson
                    • Jun 2026
                    I don’t think last(/host/key,#2) can be used directly inside Operational data. Operational data resolves macros like {ITEM.VALUE} and {ITEM.LASTVALUE}, but it does not execute raw history functions there.
                    Also, {ITEM.LASTVALUE} is not the previous value. It is the latest collected value Zabbix has for that item. {ITEM.VALUE} is the value from when the trigger changed state.
                    The workaround is to create a calculated item that stores the previous value.
                    Example:
                    Name: test.macro previous value
                    Type: Calculated
                    Key: test.macro.previous
                    Formula: last(//test.macro,#2)
                    Update interval: same as the original item
                    Then include both items in the trigger expression, for example:
                    and last(/Single/test.macro.previous)>=0
                    Then set Operational data to:
                    Current: {ITEM.VALUE1} - Previous: {ITEM.VALUE2}
                    This way {ITEM.VALUE1} shows the value that triggered the problem, and {ITEM.VALUE2} shows the calculated item containing the previous value.
                    If the item can have negative values, adjust the second condition so it does not accidentally change the trigger logic. In this example, >=0 is only safe if the value is expected to be 0 or greater.
                    Alex Robson
                    clearstackops.com
                    • uniken1
                      uniken1 commented
                      AI + advertisement(
                      #2 this is an unnecessary condition
                    • Alex Robson
                      Alex Robson commented
                      I get what you’re saying, but my original point still stands. I tested this in my environment and confirmed it working.
                      Your workaround makes sense for your specific Total Memory use case, but it is situational.
                      The reason is that your secondary item is not really storing the immediate previous value. It is copying the current memory value, and then the trigger compares the current value against the max value from the last 1 day.
                      That works for something like:
                      32 GB -> 16 GB
                      because the max value from the last day is still 32 GB.
                      But that is not the same as getting the actual previous collected value. For example:
                      20 -> 10 -> 15
                      The actual previous value before 15 is 10, but max over 1 day would still be 20. So that method is comparing against the highest value in the time window, not the previous value.
                      The method I tested is different because the calculated item uses:
                      That directly stores the second most recent value of the original item. So it is actually holding the previous collected value, not a max/min/average from a time window.
                      Test item:
                      Type: Zabbix trapper
                      Key: test.macro
                      Type of information: Numeric unsigned
                      Calculated item:
                      Name: Test macro previous value
                      Type: Calculated
                      Update interval: 5s
                      Trigger expression:
                      and nodata(/Single/test.macro.previous,30s)=0
                      Operational data:
                      Current: {ITEM.LASTVALUE1} - Previous: {ITEM.LASTVALUE2}
                      Then I tested it by sending values 5, then 1, then 0:
                      zabbix_sender -z <server_ip> -s "<host_name>" -k test.macro -o 5 && sleep 10 && zabbix_sender -z <server_ip> -s "<host_name>" -k test.macro -o 1 && sleep 10 && zabbix_sender -z <server_ip> -s "<host_name>" -k test.macro -o 0
                      When the trigger fired on 0, Operational data showed:
                      Current: 0 - Previous: 1
                      So yes, both approaches use a secondary/calculated item, but they are not doing the same thing.
                      Your method works for the specific “Total Memory decreased from a previous high value” case.
                      The #2 calculated item method is more generic because it stores the actual previous collected value, regardless of whether the value went up or down.
