SNMP switch device: add only given ports (template thing)
  • Linuxmail
    • Feb 2016
    • 9
    hi,
    I created a template for a Lancom switch. I want to monitor only a given list of ports, for example 1,2,9,10...31,49.
    I don't want to use the autodiscover thing, because I get a big item list, that I don't need/want to monitor.
    I linked the template to my switch .. but don't know, how to submit the ports, I want.
    What I have for TX in my template:
    Type: SNMP3 Agent
    Key: ifHCOutOctets[{#SNMPVALUE}]
    SNMP OID: IF-MIB::ifHCOutOctets.[{#SNMPVALUE}]
    For example, if I want to monitor port 49:
    Key: ifHCOutOctets49
    SNMP OID: IF-MIB::ifHCOutOctets.49
    So, what is the right Zabbix way, to make use of the template/macros/value?
    cu denny
  • Linuxmail
    • Feb 2016
    • 9
    Solved
    hi,
    I solved it by myself. I added to all Lancom ports a description and used for the discovery rule the ifAlias SNMP, instead of the normal ifDescr.. Than I put in every ifAlias a "| Monitor" string, I want to discover.
    With the {#snmpvalue} macro and "Monitor$" as filter, I was able to choose the ports I want.
