database monitor: odbc connection error
  • shinmorpheus
    • Mar 2022
    • 9
    Hi guys,
    i'm tryng to configure some database check on zabbix.
    I've configured all 15 ODBC monitoring (zabbix.com) but when i perform the item test i cannotct connect to odbc dsn:
    • Cannot connect to ODBC DSN: [SQL_ERROR]:[HY000][2066][[unixODBC][MySQL][ODBC 5.3(a) Driver]Connection failed due to wrongly configured compression algorithm]
    zabbix server 6.04
    ubuntu lts 20.04
    remote database mariadb 10.5.15
    isql test
    | Connected! |
    | sql-statement |
    | help [tablename] |
    | quit |
    SQL>
    odbc.ini
    [test]
    Description = MySQL test database
    Driver = mysql
    Server = 10.0.2.111
    User = test
    Password = pippo123
    Port = 3306
    Database = test
    odbcinst.ini
    [mysql2]
    Driver=/usr/local/lib/libmyodbc5w.so
    UsageCount=1
    how i need to configure the compression?
    thanks
    Daniel
    [mysql]
    Driver=/usr/local/lib/libmyodbc5a.so
    UsageCount=1
