Templating web scenarios
  • karlism
    • Sep 2015
    • 10
    Hello!
    I've been searching this forum and saw lot of posts that templating web scenarios was not possible with older Zabbix versions. Is it possible with recent Zabbix versions?
    If it is possible, can anyone please point me to an example of template that is using web scenarios? Because I looked and couldn't find any.
    Thanks!
  • LenR
    • Sep 2009
    • 1011
    Here's an example that does tests on {HOST.DNS1}. I doubt it will work as-is, you'll at least need to delete the item that refers to an external script.
    • karlism
      • Sep 2015
      • 10
      LenR,
      Thank you for your help, but this is not what I was looking for. I was asking about Web Scenarios that are described here:
      And the issue is that I don't know how to insert Web Scenario (and triggers that are monitoring it) into the template and I'm not really sure if it is supported.
